Eagle H beams hitting block... 455 build
Old Nov 12, 2013 | 04:32 PM
jensenracing77's Avatar
Has anyone had to clearance the block for there Eagle H beams? I did a search but could not find anything. Mine are hitting the block.
Old Nov 12, 2013 | 05:05 PM
cutlassefi's Avatar
Yes everytime. You don't need to remove much though. And I use the thickness of a 8" black tie wrap to gauge the clearance between the block and the rod bolt.
Old Nov 12, 2013 | 05:55 PM
Old Mar 18, 2021 | 12:56 PM
HolleyGreenGiant's Avatar
I am bumping this thread because I just snagged some eagle rods for my 455.
Mark, would you be kind enough to pop the pictures on here? That way future folks can see what is going on too.
Old Mar 18, 2021 | 06:01 PM
cutlassefi's Avatar
Yes I can post those in the am.
Old Mar 19, 2021 | 09:52 AM
cutlassefi's Avatar
This is across from the existing notch by the pan rail.
Old Mar 19, 2021 | 10:20 AM
That doesn't look that bad. Which cylinder is that? And is it only 1 cylinder that needs to be clearanced?
Old Mar 19, 2021 | 11:37 AM
cutlassefi's Avatar
It doesn’t take that long if you have the right grinder Etc. and you have to do all eight cylinders, not sure which one that one is.
Old Mar 19, 2021 | 12:43 PM
grannys442's Avatar
Anyone know if the 400 G block also required notching when running Eagle H rods?
fly1
May 2, 2023 06:15 AM
Four Hundred Forty Two
Jul 24, 2020 01:13 PM
69Chrgr
Feb 26, 2020 11:37 AM
bostonstenthman@gmail.com
Aug 2, 2015 07:44 PM
chasman414
Dec 8, 2012 08:18 AM
