Drilling enlarging push rod holes in C heads
Old July 10th, 2021, 11:22 AM
grannys442's Avatar
My set up will be C heads, hydraulic roller with .535” lift, HS 5016 rockers. Just a cruiser.
Harland Sharp footnote says pushrod holes must be drilled to 9/16. I plan to use 5/16 pushrod (Trend or Smith).
Wondering if I actual need to drill out heads or not…as per Harland Sharp. Anyone have working knowledge of a similar set up.
I’ll eventually mock everything up to know for sure…but all the darn back orders for parts make it difficult.
If i knew for sure that heads must be drilled for clearance even with 5/16 pushrods, i could knock that out while waiting on parts. But don’t want to if It’s not absolutely required.
It appears hydraulic roller lifters slightly increase the unfavorable push rod angle since they’re taller (i assume they’re taller than a non-roller)
thanks,
Adrian
grannys442 is offline
Old July 10th, 2021, 11:28 AM
Oldsmaniac's Avatar
I would do a try and see before drilling.... what is your block? 455?
Oldsmaniac is offline
Old July 10th, 2021, 11:37 AM
grannys442's Avatar
It’s a 400 G block.
Old July 10th, 2021, 12:02 PM
Run to Rund's Avatar
I also recommend waiting until you can mock up everything. Even with 3/8" pushrods and high lift, I only had to egg shape the end of the hole a bit on the block side of the heads. I used a die grinder with carbide bur. Drilling the holes is not so easy, as the bit will tend to catch, jam, and try to spin the head, etc. It also removes meat in places where you are better off leaving it.
Run to Rund is offline
sxsleeper
March 20th, 2021 02:45 PM
doggonn
Tech Editor's Desk
May 1st, 2020 04:58 PM
VinMichael
October 26th, 2019 03:21 PM
easytobedead
February 14th, 2013 10:07 AM
Stevec
August 10th, 2012 11:13 AM
Quick Reply: Drilling enlarging push rod holes in C heads
