C heads 3/8” or 5/16” pushrods
Old Oct 25, 2019 | 03:33 PM
VinMichael's Avatar
I have a set of C heads that have been pocket ported and tapped for 7/16” x 7/16” rocker studs.
What type of pushrod should I plan on running. Will 3/8” work, or an I stuck with 5/16”
I know all castings are different, but figured I’d ask.
Old Oct 25, 2019 | 03:58 PM
cutlassefi's Avatar
I’m not sure what the rockers stud size has to do with anything but I’d use a good 3/8” pushrod. I’m guessing you’ll be using guide plates as well?
Old Oct 25, 2019 | 06:37 PM
VinMichael's Avatar
Yes I’m using guide plates
Would you consider running anything besides a 5/16” push rod with a 3/8” x 5/16” rocker stud
Old Oct 26, 2019 | 01:26 AM
Schurkey's Avatar
When I put "C" castings onto my 455, I spent hours grinding the pushrod holes just to get 5/16 pushrods to clear when using "Ford" roller rockers.
I can't imagine what it would take to find room for 3/8 pushrods.
I am under the impression that some "C" castings need more work for pushrod clearance than others--the difference being the lifter bank angle of the block they came off of. But I've been wrong before.
Old Oct 26, 2019 | 05:26 AM
cutlassefi's Avatar
Again I’m trying to figure out why you think the pushrod diameter has anything to do with the rocker stud size.
Old Oct 26, 2019 | 06:59 AM
67OAI's Avatar
Old(s)GuysRule
Vin, what is the purpose of your engine build? Are you building a serious race engine or just a mild "have fun" engine? To use 3/8" pushrods in an Olds engine with any Olds iron head casting you will have to open up the pushrod holes. I would stay with 5/16" pushrods unless it was an all out race engine. Just my two cents. BTW, I personally have run 5/16" pushrods in a mild E block with C heads and a .600" lift solid lifter cam and Harland Sharp rockers with no problem.
Old Oct 26, 2019 | 09:12 AM
VinMichael's Avatar
Good point about the bank angle. I’ll have to check on that. Not sure which engine these heads came from.
Would you run a 3/8” pushrod with a COMP MAGNUM roller tip rocker kit and a 3/8” x 5/16” rocker stud on stick iron heads.
Would you run a 5/16” pushrod with Edelbrock heads.
It’s more of a have fun engine. But to run a 150 shot of nitrous at the track.
Torker intake
KB hyper 277 +.040”
Torque plate honed
Pocket ported C heads with good valve job and Manley stainless valves. Heat risers filled, exhaust dividers welded.
PRW stainless 1.65 roller rockers
Comp Cams 995 valve springs 115 seat pressure
Extra capacity oil pan with trap doors
Standard N crank
Stock rods resized with ARP bolts
Balanced
JM 25-28 cam, 236 @ .050” .523” and .544” lift 108 LSA
Holley 3310 vac secondary 750 carb
9.7:1 compression
Old Oct 26, 2019 | 10:32 AM
67OAI's Avatar
Old(s)GuysRule
Vin, I assume you have a "F" 455 block. "C" heads were used on that block the first few years of manufacture thus the pushrod holes would be correct for the 39 degree lifter bank. Those Comp valve springs probably give you no more than 325 open pressure. You should be safe using a 5/16"pushrod with that combination. I am not personally familiar with the PRW rockers but they may bring your pushrods closer to the edge of the pushrod hole thus requiring some clearancing. Of course you would need 5/16" guide plates with the 5/16"pushrods. The critical part here is getting the correct length pushrod.
Old Oct 26, 2019 | 01:59 PM
cutlassefi's Avatar
Would you run a 3/8” pushrod with a COMP MAGNUM roller tip rocker kit and a 3/8” x 5/16” rocker stud on stock iron heads.
Ok I’ll bite. You always use the biggest, stiffest pushrod you can fit in it.
Old Oct 26, 2019 | 03:21 PM
70W-32's Avatar
To run 3/8 push rods on cast iron Olds heads you must open the pushrod holes to 9/16"
cdrod
Jan 15, 2016 09:41 PM
Erinyes
Aug 12, 2014 05:06 PM
joepenoso
Jun 14, 2013 05:33 PM
CutlassLegend
Sep 21, 2011 02:56 PM
defiant1
Mar 19, 2011 07:14 AM
