Differences in radiators.
Old Sep 30, 2013 | 08:24 AM
I have a very thin radiator from my parts lot I got recently. I think it may be a 2 core, or maybe a 3.
My 442 is running a replacement autozone one now, and if I wanted to go to stock, are the end tanks the same for all the 67 radiators? As in, could I ave the end tanks taken off of this thin one and made into a new 4 core that looks correct? Or, am I better just looking for a 4 core to rebuild?
Thanks.
Old Sep 30, 2013 | 08:51 AM
tmaleck's Avatar
Thanks.
Back when I did cars for a living, brass end tanks were almost always re-used when doing a radiator core replacement. Tanks are generally wider than the core so they will accept a two three or most times a four row core. That being said, are you sure you need a 4 row?
Tim
Old Sep 30, 2013 | 10:29 AM
Well, more cores are nicer, I guess.
But, it's a 442, 67, automatic, A/C. Has a 4 blade fan, don't think it has a clutch.
Had a busted fan shroud, which I have replaced. Factory, I think, except for cam.
I believe A/C required heavy duty cooling option, but that says, per oldsmobility.com,
"Includes heavy-duty radiator and water pump, Thermo-Cool engine fan and Delcotron. Included in C60" where C60 is AC. I don't know what a Thermo-Cool engine fan or a delcotron is.
Old Oct 3, 2013 | 07:15 PM
A Thermo-Cool fan is a clutch fan.
A Delcotron is an alternator.
A/C cars had a three- or four-core radiator, a fan clutch, a six (or maybe seven) blade fan, a fan shroud, and a higher-output alternator, among other things.
I would recommend against under-cooling your car.
Old Oct 4, 2013 | 12:22 AM
nsnarsk65cutlass's Avatar
2 tube and 3 tube radiators have smaller tanks than 4 tube on crossflow radiators.Core is the center part the tanks attach to.
Old Oct 7, 2013 | 03:00 PM
Ok. Thanks for info. I shall not undercool the car, and will look at the fan more closely, with a picture, soon. I wish I had remembered to do it yesterday when I was fleeing hoodlums with it.
Aceshigh
Oct 13, 2010 06:18 AM
viper771
Mar 6, 2010 12:49 PM
pureplaya442
Sep 13, 2009 03:12 PM
442_Mustang
Aug 19, 2009 03:53 AM
mp71conv
Aug 2, 2009 11:18 AM
