Aluminum Radiators
Old Sep 12, 2009 | 06:19 AM
pureplaya442's Avatar
Aluminum Radiators
Im in the process of shopping around for an aluminum radiator, and I want something thats going to keep my Big Block nice an cool. Who's makes a good aluminum radiator out there? Im also thinking of running electrical fans vs. the old mechanical fan. Any suggestions?
Old Sep 12, 2009 | 09:38 AM
nickd's Avatar
I bought a four row from Genesisautoparts.com for $160 shipped. I had to make up some new top brackets but it turned out well.
Old Sep 12, 2009 | 10:15 AM
I would check out Summit. They have house brand parts that are reasonably priced and perform just as well as an expensive unit like Griffin or BeCool.
Old Sep 12, 2009 | 11:48 AM
My442's Avatar
I have a Be Cool.
Dropped my running tempreture from 210 to 180.
It replaced a recored 4 core.
Old Sep 13, 2009 | 07:29 AM
Thats about what I want to be running, about that 180 degree range. Now your Be Cool do you have electric fans, or are you still using the mechanical fan?
Old Sep 13, 2009 | 03:12 PM
My442's Avatar
I run a Be Cool radiator, factory fan shroud, factory clutch fan, and a high flow 180 degree thermostat.
The coolant is 30% green antifreeze, 70% distilled water, and a pint of NoRosion.
My car will run at 180 degrees even if it is 90 degrees out.
AZ455
Aug 9, 2016 11:47 AM
RandyS
Jun 25, 2015 02:57 PM
69350rocket
Aug 8, 2011 02:52 PM
jo75olds
Jan 31, 2011 07:55 PM
mp71conv
Aug 2, 2009 11:18 AM
