Engine bolt question
Old Oct 3, 2013 | 06:38 PM
foo's Avatar
foo
I was going through all my service manual, engine assembly manual.
Most I found was it wants you to dip bolts in oil for helping with torque specs
Are there any bolts for a 455 engine that require loctite or sealer, or you would recommend put on?
Old Oct 3, 2013 | 06:47 PM
I don't know of any. If you torque them properly, they shouldn't back out.
Old Oct 4, 2013 | 11:05 PM
svnt442's Avatar
No. All of the holes are blind. Use oil to get the proper torque readings.
Old Oct 5, 2013 | 01:01 AM
foo's Avatar
foo
Thank yous The build continues.
Old Oct 5, 2013 | 10:11 AM
Actually, the two bolts that hold the t-stat housing to the intake are open at the bottom and can use sealant.
Old Oct 5, 2013 | 10:20 AM
Macadoo's Avatar
Perfect timing Joe, I was just wondering about that.
Old Oct 5, 2013 | 11:49 AM
Octania's Avatar
good call Joe
The distributor clamp bolt also goes thru, but into a cavity that won't leak so that's not an issue.
The tstat housing bolts are the main concern.
Form-a-gasket #2 non-hardening is my suggestion.
There is one bolt that goes into the intake also, Left of the carb and fwd a bit, where the dashpot goes sometimes. It's just sealing vacuum though so as long as any bolt is in there that should be OK.
Old Oct 5, 2013 | 01:43 PM
I use pipe sealer with Teflon on the thermo bolts.
Old Oct 6, 2013 | 09:38 AM
Yup, forgot about that one. Not all intakes have it, however. Back in my young and stupid days I removed that dashpot on my first car (1968 VC) then couldn't figure out where the massive vacuum leak was coming from.
Old Oct 8, 2013 | 09:41 AM
Octania's Avatar
Wow, I have never done anything that stupid
[I almost said that with a straight face, too!]
Did you spill vacuum all over the engine?
tmcfall
May 29, 2024 12:41 PM
72442conv
Mar 19, 2012 07:14 AM
68Tom
Apr 25, 2011 05:34 PM
olds4life
Oct 5, 2010 05:18 AM
dman0712
Drivetrain/Differentials
Mar 16, 2010 07:40 PM
