Cutlass with toro oil pan
Old February 7th, 2019, 09:54 AM
Achcoastal's Avatar
Before I put my 70 cutlass convertible away for winter, I decided to have a friend tackle a leaky oil pan gasket. This is a 455 out of a 70 toro ( stamp pad # 30m7xxxxx) it has the pan with the internal hump for the trans axle. I figured I would swap out the pan with a new big block cutlass/442 stock unit that I purchased. I was out of town when he went to work on the car. He did it on a lift while blocking the engine up to get enough clearance. He called me later that day and said that he got the old toro pan out and the cutlass pan in no problem but then said when he went to lower the engine the new pan would ready on the crossmember and not line up with mounts. I told him put the old pan back with the new gasket which he did. The good news is no more gasket leak but I wonder why the cutlass pan didn’t fit. The fan fits perfect in the shroud, so I think the motor mounts are the right ones otherwise the fan would strike the shroud. Any ideas?
Achcoastal is offline
Old February 7th, 2019, 10:02 AM
RWD pans came from the factory in Cutlass cars. Without photos it's impossible to say what the issue might be.
joe_padavano is offline
Achcoastal
May 12th, 2018 04:42 AM
defiant1
April 23rd, 2014 03:40 PM
brandon 455
March 29th, 2014 01:49 PM
Jolly Green
February 14th, 2012 08:37 PM
Oldsmaniac
July 27th, 2010 04:45 AM
Quick Reply: Cutlass with toro oil pan
