Correct timing marks
Old Apr 11, 2015 | 05:00 AM
lonestarjarhead's Avatar
I'm ready to reassemble my 455. I've donut that the 71 Chassis manual shows timing marks on cam and c/s gear both at 12 o'clock position, while the period Chilton and instructions with the timing set show cam mark at 6 o'clock and c/s gear mark at 12 o'clock. Which is correct?
Old Apr 11, 2015 | 05:55 AM
pogo69's Avatar
morgan
the chasis manual is correct chiltons is incorrect for oldsmoblie
Old Apr 11, 2015 | 06:19 AM
You've donut?
Me want donut.
Actually, neither is wrong.
Crank at 12 / Cam at 6 (like a Chebby) will get you TDC ignition on #6 cylinder.
Crank at 12 / Cam at 12 will get you TDC ignition on #1 cylinder.
Old Apr 11, 2015 | 06:20 AM
They are both correct.
Once again, it doesn't matter. The crank rotates twice for every one turn of the cam. Line them both up at 12:00 - 12:00. Now turn the crank one turn and they will be 12:00 - 6:00. All that matters is that in one orientation the #1 cylinder is at TDC on compression and in the other orientation the #1 cylinder is at TDC on exhaust.
Old Apr 11, 2015 | 06:30 AM
Which means that you either stab the distributor pointing to #6 or #1 depending on which mark you use.
Old Apr 11, 2015 | 10:12 AM
455 timing marks
Thanks for the information. Should be able to make it work now. The "donut" started out as "noticed" until spell check got ahold of it! Thanks again.
Carshinebob
Sep 11, 2013 04:06 AM
bullet1
Sep 25, 2009 05:44 PM
Gbobby
Feb 4, 2009 06:31 AM
cisco88
Oct 17, 2008 07:12 PM
MIRADAMANia
Apr 22, 2008 01:00 AM
