Oilprimed the engine,but cant see it reach heads.
Hello, i have try to prime the engine on the pump with a battery drill, Well its not going so fast but i get Oil up in the hole for Oil pressure gauge in front and i see the Oil pressure in the disturbutor hole,
but cant see it comes out from the small hole in the lifters yet with that speed. Could it be cause the batterydrill goes to slow it not pump enought? The pump is a highpressure pump type.
Thinking to install the starter and crank it on the flywheel instead.
I usually prime the engine with valve covers on. The action of the lifters and rockers while in motion assist greatly in geting oil up to the rockers. As long as rockers were oiled during assembly you should be fine.
Yes i spin it counter clockwise, i forgot i didnt have the plug in the Oil gauge hole in front in first prime test, it was like a vulcano blowing up Oil, so pressure it is, Well ok i will try a Electric drill next time and see if it will come Oil up then, the batterydrill was almost empty for battery too, lol so it not help so much more. I Just fill the engine with oil so it was a little Oil on the end at the dipstick, i guess its enought to that the oilpump will suck up Oil. When i drill it,it feels a little heavy too..
Well i guess its no problem with the engine then. I turn it around some times too with hand on the crankbolt after have stand still maybe 4-5 yrs Inside a garage, so its hope
OK, i guess to get Oil in to all rod/crank bearings? At least i prime it a little before beginning to rotate the crank,and after, i dont know if its so smart to rotate a engine many times on "dry" bearings after engine storage from some years.
Don't rotate engine until you have primed the motor with oil. Getting oil pressure to all the bearing is a must on a long standing engine.
You have primed the engine, as Oldsmaniac said, running the engine will see oil to the rockers due to the mechanical action of the lifters much sooner than winding the pump for ages with a drill.
Splash some oil round the valvegear before you first fire the engine up and all should be fine.
Roger.
Roger.
Have prime the engine again with my new charged batterydrill,it was enought,i got Oil to the lifters now in both heads, i needed to turn the engine many small times around and prime between untill i have complete 1 turn on crank, so i got Oil out of all lifters, when the engine just stood still and i prime it comes Oil out of only 5 og 8 lifters (on one side) until i turn the engine around a little bit so the 3 lifters left get Oil too.. Anyway, mission complete.
now i can take out the new Oil and filter of engine again
Took of the Oil Pan today after prime the engine, and see it have a sement of microscopic metal in the Oil.. Is this normal after a engine have new parts like piston and rings, and all the bearings in crank,rods,crankshaft? It have been dynotested after rebuild and not much used after...
Just hope its not bad, and can be used without problem with new Oil..
I clean the oilpan after.
OK, it was something like that i tought, guess it will be ok then. Installed a new drain plug with magnet if it will pick up something later...
costpenn
Body work
Oct 27, 2012 06:02 PM
