Coolant Measure
Old July 29th, 2009, 01:11 PM
Englishman
DAN76's Avatar
Coolant Measure
After a complete flush out, how much coolant fluid should be put into the system on a 425 and what ratio of coolant to water is recommended?
DAN76 is offline
Old July 29th, 2009, 01:17 PM
My stuff says 50/50 on the bottle.
Jamesbo is offline
Old July 29th, 2009, 01:43 PM
Are you using imperial gallons or US gallons?
Seriously, I just fill with 50/50 mix until the radiator is full, let the air bubble out, top off, cap, and run the engine until the thermostat opens (the upper radiator hose will get hot). Shut off, cool down, and top off again.
joe_padavano is offline
Old July 29th, 2009, 01:44 PM
Englishman
DAN76's Avatar
cheers!
do you know the correct measurement of mixed fluid that should go into the engine or is it just a case of eyeing it up to the rad cap?
DAN76 is offline
Old July 29th, 2009, 05:13 PM
Lady72nRob71's Avatar
Greetings to England!
It will be between 16 and 20 litres if you pulled the block drain plugs, but eyeing it is the best. If you did not pull the block plugs (or if you do not have any) then you will put in quite a bit less.
If there is no overflow bottle, I think the right level will be 1-2" below the fill cap to allow for expansion. If you do have the O/F bottle, fill up all the way and fill the bottle to the full mark.
Use 50/50 and you will be fine.
Lady72nRob71 is offline
Old July 29th, 2009, 11:35 PM
Englishman
DAN76's Avatar
sorry Jo i think our posts crossed over there.
Cheers guys!
Oh, one other thing... do you use de-ionised water ?
DAN76 is offline
Old July 30th, 2009, 02:38 AM
Yellowstatue's Avatar
Smile Drink up
I use distilled water from the drug store or clean water from my de-humidifier in a 50/50 mix...cheers
Yellowstatue is offline
Old July 30th, 2009, 05:53 AM
I usually just use tap water. IF changed regularly it shouldn't have much of an effect on your cooling system. Of course, if I had a $1200 Griffin 3 core radiator I would use distilled water.
Olds64 is offline
coldfire
Wheels and Tires
July 22nd, 2013 05:49 PM
defiant1
May 2nd, 2011 07:52 PM
ztim
December 22nd, 2006 10:20 PM
Redog
December 13th, 2006 06:14 AM
Diabolus
July 23rd, 2004 04:35 AM
Quick Reply: Coolant Measure
