Comp cams evolution roller lifters
Old Aug 19, 2025 | 10:44 AM
maddoctor's Avatar
Hi, I'm looking for info on the comp cams evolution roller lifters. Right now I have comp cams rollers from circa 2010 and they seem to bleed down overnight. I have bit of lifter rap for 15 to 20 seconds after start up. In the spring even after I pre oil the engine for 5 minutes, on start up its there. My question is are the Evolution rollers better.
Old Aug 19, 2025 | 11:29 AM
cutlassefi's Avatar
Yes. They had some issues a while back, but seem to have gotten those worked out. I just did a couple of builds with them, no issues so far.
Old Aug 19, 2025 | 02:09 PM
maddoctor's Avatar
Thank you
Old Aug 19, 2025 | 09:41 PM
olds 307 and 403's Avatar
Out of Line, Everytime😉
Was tbe issues with the hydraulic portion? As you know Mark, I have a set from you when they first came out, hopefully will run them soon. Are the replaceablr hydraulic portion readily available from Comp
Old Aug 20, 2025 | 03:58 AM
BillK's Avatar
Was tbe issues with the hydraulic portion? As you know Mark, I have a set from you when they first came out, hopefully will run them soon. Are the replaceable hydraulic portion readily available from Comp
Make sure and take a close look at the snap ring that holds the cartridge in place. The early ones had a snap ring that would actually hit the pushrod. Comp has the correct rings and will send you a set for free if you need them.
Old Aug 20, 2025 | 06:35 AM
Thanks Bill, I will request a set if needed. I am planning on 3/8" push rods, which will probably have interference.
Old Aug 20, 2025 | 06:55 AM
BillK's Avatar
Here is a picture of the new clip. Easy to see the difference.
Old Aug 20, 2025 | 01:32 PM
OLDSter Ralph's Avatar
Thanks BillK.
Old Aug 20, 2025 | 03:23 PM
Here is mine dated 02/16/22
Old Aug 20, 2025 | 05:50 PM
maddoctor's Avatar
Ok the new rollers are better, but are they the same height as the old ones I have. If there is a difference in height the geometry of my rockers and pushrods will be effected and probably require new pushrods and rocker lash adjustment.
Old Jan 10, 2026 | 03:58 AM
I will finally be installing these in the next month or so. Hopefully it is a simple process to get the new improved C Clips, contacted Mark for a contact. I need to pull the bodies then soak and clean everything in mineral spirits.
Old Jan 10, 2026 | 11:34 AM
BillK's Avatar
contacted Mark for a contact..
No need to get Mark involved. Send an e-mail to Comp with their contact form. Thats what I did and I had a set of the new clips in a couple of days. You will need a very good set of snap ring pliers with very small tips.
Old Jan 10, 2026 | 12:46 PM
Sent him an email anyways about the rest of the payment for the new heads. No response, so this is appreciated. I will send an email, hopefully they send them out the updated clips.
Have to see what I have for pliers, have a few sets.
Old Jan 10, 2026 | 01:27 PM
Email sent, couldn't find it till I separately searched for an email. Thanks Bill
Old Jan 10, 2026 | 02:57 PM
Those "New improved C clips" have been around for decades. Over 55 years ago, an engineer at Oldsmobile by the name of Rich Powers used them on his W-31 NHRA stocker. I can believe others used them also. I would think they would be wanted for any cam that had to set valve lash (solid lifter).
Topline Lifters had a line of lifters that came with those clips several years ago. I contacted Mark Remmel years ago (2018 ?) looking for lifters with those "new improved C clips". He sent me Lunati "Microtrol" lifters.
Those C clips are called "Internal Snap Rings". You might find them at a farm supply store. They come in a variety of sizes. I am sure McMaster-Carr has them.
https://www.mcmaster.com/products/sn...type~internal/
Old Jan 10, 2026 | 03:33 PM
Not sure why they used the style clip they did. New ones should be free and not interfere.
Old Jan 10, 2026 | 07:14 PM
BillK's Avatar
Ralph,
Comp used an unusual ring on these lifters. When I needed them I also checked McMaster and could not find them. I get stuff from McMaster at least once a week. Not saying they cant be found with some searching but its a lot easier to get them from the source. Comp sent the correct ones out so it was not a problem.
Have you actually seen the Evolution lifters ? They have a separate removable cartridge in the body. Looks suspiciously like some type of import engine lash adjuster.
Old Jan 10, 2026 | 08:18 PM
Ralph,
BillK, If you can get the C Clips from Comp Cams, that would be great. Next time you get some, measure them and save the sizes for reference.
I have not seen, nor do I have interest it Comp Evolution lifters. I was speaking generally about "all" valve lifters. Those "hairpin" clips can be a problem if you don't have "preload" on the lifters.
Old Jan 10, 2026 | 08:31 PM
If I don't hear back Mark is going contact them. Hopefully their quiet. Going to get a magnetic base and dial indicator to set preload on them.
MartinH
Jul 1, 2022 04:30 AM
Gene kerr
Apr 21, 2022 08:56 AM
cdrod
Jun 9, 2021 03:07 PM
dfire25
May 1, 2015 02:57 PM
Redog
Aug 14, 2008 06:56 PM
