CDI with HEI install
Accel 300+ install
Hi to everyone,i ordered an accel 300+ box wich also include the 375+ box,now my question is should i take the module out of my hei when istalling the cdi unit and lock the dist.? what about spark plug gap?
Panos
Panos
Panos
PM this guy. I believe he has experience with these units. I don't. He's on the forum quite often
https://classicoldsmobile.com/forums...utlassefi.html
Panos
thats why i put it up here to see if someone use this box maybe.
Panos, you should have just emailed me! I believe you'll be bypassing the existing module. There should be very detailed instructions in there. If not I can access them or go to www.accel-ignition.com they'll be there too.
BTW, you're not a bother. Don't forget to check the rev limiter on the box, they're normally set at about 4500 from the factory.
Try this;
http://www.accel-ignition.com/pdf/49322.jpg
Try this;
Try this;
Try this;
joepenoso
June 4th, 2014 01:56 PM
dallasite21
January 30th, 2010 04:57 PM
