CDI with HEI install
Old Jan 21, 2011 | 04:33 AM
panos's Avatar
Accel 300+ install
Hi to everyone,i ordered an accel 300+ box wich also include the 375+ box,now my question is should i take the module out of my hei when istalling the cdi unit and lock the dist.? what about spark plug gap?
Panos
Old Jan 21, 2011 | 09:47 AM
panos's Avatar
No one knows about this unit?
Old Jan 21, 2011 | 10:07 AM
citcapp's Avatar
Panos
PM this guy. I believe he has experience with these units. I don't. He's on the forum quite often
https://classicoldsmobile.com/forums...utlassefi.html
Old Jan 21, 2011 | 10:20 AM
panos's Avatar
Originally Posted by citcapp
Panos
Well,i know him because he built my motor i just feel a little uncomfortable asking him questions all the time busting his n**s
thats why i put it up here to see if someone use this box maybe.
Old Jan 21, 2011 | 10:22 AM
citcapp's Avatar
He won't mind I ask him questions all the time
Old Jan 21, 2011 | 06:23 PM
cutlassefi's Avatar
Panos, you should have just emailed me! I believe you'll be bypassing the existing module. There should be very detailed instructions in there. If not I can access them or go to www.accel-ignition.com they'll be there too.
BTW, you're not a bother. Don't forget to check the rev limiter on the box, they're normally set at about 4500 from the factory.
Try this;
http://www.accel-ignition.com/pdf/49322.jpg
Old Jan 22, 2011 | 01:28 AM
panos's Avatar
Try this;
Thanks a lot Mark! in case im gonna use the 375+ box that comes with it,should i lock the dist.and adjust timing through the box instead?
joepenoso
Jun 4, 2014 01:56 PM
MX442
Mar 25, 2012 01:00 PM
oldscruiser
Feb 15, 2011 12:44 AM
Oldsmobile Jo
May 30, 2010 07:58 AM
dallasite21
Jan 30, 2010 04:57 PM
