Can anyone ID this water pump?
This water pump was on an Olds 350 motor I just picked up recently. A friend of mine thinks it might have been for one of the W-machine applications. The casting number is 400269 D2 with a smaller 332 (date code?). Can anyone tell me about this pump? See enclosed pictures.
Thanks.
Attachment 207308
Attachment 207309
Thanks.
Attachment 207308
Attachment 207309
That water pump will fit on a 350 engine but it was used for 1968 and 1969 versions on the 400 and 455 engines with A/C or heavy duty cooling. It also applied to the W-30, W-32 and Hurst Olds. The "332" is the Julian casting date, which would be either the 332nd day of 1967 or 1968.
Randy C.
Randy C.
Thanks,
My friend wasn't sure but he had a suspicion that it was for applications other than the 1969 Olds 350 I recently got. The engine is a strong runner that has since been cleaned up, re-gasketed, painted, and had several components replaced, including the water pump. I replaced it with one from my local auto parts store.
