Water Pump Confusion
Old May 3, 2016 | 10:21 AM
rand5204's Avatar
I'm working on a '70 455 out of a 442. I have two water pumps with code 400269 on them. One is a 256 date, the other is 237. At least one source I have seen identifies these as correct for my car. Others identify them as 68-69 400 & 455 pumps. Can anyone sort this out for me?
Old May 3, 2016 | 11:57 AM
rcorrigan5's Avatar
Randy C.
The 400269 water pump is for '68 and '69 400 & 455 engines with A/C or heavy duty cooling, as well as for the W30, W32 & Hurst Olds.
The correct water pump for a '70 455 with heavy duty cooling or A/C (also W30) has a casting number of 404847. The water pump used without A/C or heavy duty cooling was 404584.
Randy C.
Old May 3, 2016 | 01:14 PM
68442's Avatar
The 269(68-69) and the 847(70) are "dimensionally" the same(height). That is why they may be listed for a similar application
Old May 3, 2016 | 09:08 PM
70Post's Avatar
I've had a VERY ORIGINAL '70 W30 motor here in the recent past that had a 269 pump on it (motor was pulled from the car prior to '72 and all other parts were original/correct). My bet is it's fine and they possibly used up the inventory and then switched to the 847 pumps.
Old May 5, 2016 | 04:41 AM
rand5204's Avatar
Thanks for all the replies. My car was built in Fremont so, as suggested, I wonder if they were just slow in using up pump inventory
Lady72nRob71
Oct 8, 2013 07:16 PM
Nor Cal Andy
Mar 29, 2012 07:27 PM
jag1886
Oct 15, 2010 12:06 PM
yeahbuddy
Aug 19, 2010 01:15 PM
72Ctlss
Jun 23, 2009 03:12 PM
