Cam card
Old May 21, 2023 | 11:57 AM
bas's Avatar
bas
Cam card
Does anyone have the timing events for TRW. TP242 or Sealed Power. CS-1023 R ? I have the duration and lift and LSA but need opening and closing events, couldn't fine online , thanks.
Old May 21, 2023 | 04:29 PM
BillK's Avatar
I probably have them at the shop. Ill try to remember and look in the am
Old May 22, 2023 | 04:22 AM
BillK's Avatar
The Sealed Power catalogs I have here do not give opening and closing numbers. You should be able to figure them out from the durations and centerlines.
In case you dont have all of it this is all they show:
Duration @ .050 214/224 Duration @.006 290/300 Intake centerline 107 exh centerline 117
It looks like and probably is the same as the Melling 25211 The .050 numbers for that cam are:
In opens 0 TDC closes 34 ABC
ex opens 49 BBC closes 5 BTC
See page 14: https://www.melling.com/wp-content/u...ications-1.pdf
Old May 22, 2023 | 10:51 AM
bas's Avatar
bas
Thanks for that.
Old May 25, 2023 | 08:25 AM
anoldsman's Avatar
Here is the math. I hope that it helps. Also, please remember that this does not account for any offset in the designs. This math works for 0.050" or 0.006" or any lift point.
Intake Centerline = Lobe Separation - Advance = 112 - 5 = 107
Exhaust Centerline = Lobe Separation + Advance = 112 + 5 = 117
Lobe Separation = ( Intake Centerline + Exhaust Centerline ) / 2 = (107 + 117) / 2 = 112
IO = ( Intake Duration / 2 ) - Intake Centerline = (214 / 2) - 107 = 0 BTDC
IC = Intake Duration - IO + 180 = 214 - 0 - 180 = 34 ABDC
EC = ( Exhaust Duration / 2 ) - Exhaust Centerline = (224 / 2) - 117 = -5 ATDC
EO = Exhaust Duration - IO + 180 = 224 - (-5) - 180 = 49 BBDC
Dream67Olds442
Aug 25, 2021 01:57 PM
jpaulwhite
May 14, 2012 04:46 PM
spf1410
Apr 3, 2010 07:11 PM
w-30dreamin
Mar 19, 2010 04:22 AM
344870M
Aug 25, 2009 03:28 AM
