C Heads
Old Oct 14, 2013 | 05:38 PM
Stevec's Avatar
C Heads
Got a set of C heads that I might e selling. The numbers on them are as follows 394 548 299, can someone tell me what year? What they came off? Large or small head?
The heads had the following done:
Magnafluxed
Resurfaced
8 new exhaust valves
8 new intake valves
8 new exhaust seats
16 new valve seals
8 new intake seats
5 new guides
Had A.I.R bumps ground down
Complete valve job
Mark CutlassEFI supplied all the springs and hardware
Ill throw in a set of chrome tall stamped Steele valve covers
They have a set of harland sharp S50026A roller rockers 1.6 ratio
Ill take the roller rockers off if you don't want them
$650 for the heads and rockers
These heads are ready to go
Bare with me I've never shipped anything his big/heavy
Old Oct 14, 2013 | 05:55 PM
Octania's Avatar
"Bare with me"
You first...
Old Oct 15, 2013 | 04:36 AM
Chesrown 67 OAI's Avatar
Magnafluxed
Resurfaced
8 new intake valves
8 new exhaust seats
16 new valve seals
8 new intake seats
5 new guides
Complete valve job
$850 obo for the heads and rockers
$650 obo for the heads
At the risk of being corrected, it is my conclusion that the only way to identify which year the head was cast or made is if the head has a stamped code on the end of the head that would identify the vehicle it was installed in. Since they used C heads on 67 -69 cars the julian date code does not tell the year? ( 299 is the Julian date code on your head) - stands for the 299th day of the year -- but which year? Ya cant tell!!!
Old Oct 15, 2013 | 11:28 AM
hurst68olds's Avatar
Has this pair always been together?
Are they both "299"? (October 26th) 10/26 was a Wednesday in '66 / Thursday in '67 & Saturday in '68, I'm not sure I've seen a Saturday casting date.
Are they both large or small heat crossover?
Is there a stamped engine unit number on the end of one of the heads?
Old Oct 15, 2013 | 11:32 AM
Big or small valve heads? What did you buy? You have valves listed in your original "shopping list".
Here's a '67 442 head w/engine unit number stamping.
Old Oct 15, 2013 | 12:18 PM
Mikes442's Avatar
This was on another thread.
66-67 heads had the small hole cross over and the 68-69 had the large cross over. (The hole that feeds hot air under the carb.)
Narrows it down.
Mike
Old Oct 15, 2013 | 03:50 PM
Stevec's Avatar
I bought them a year ago and was told they were large valve,yes they are both 299 and they are both small heat cross overs. Just wanted to know as much as possible in case someone wants to buy them.
Old Oct 15, 2013 | 03:54 PM
Stevec's Avatar
I couldn't find a stamped engine unit number.
Old Oct 20, 2013 | 02:25 PM
Stevec's Avatar
$650 for the complete set!
Old Nov 20, 2013 | 10:42 AM
george landis's Avatar
c heads
Still for sale? I'm in lower Alabama. No numbers stamped on the pad at the end of head?
Old Nov 20, 2013 | 11:24 AM
Stevec's Avatar
George ill check for numbers, they are still for sale.
64 CUTLASS KEN
Dec 7, 2020 06:43 AM
olds4life
Dec 25, 2012 12:56 AM
Oldsmaniac
Nov 1, 2010 06:37 PM
gearheads78
Nov 10, 2009 09:31 PM
DarkStar
Oct 21, 2009 07:35 AM
