Buying car at 4700ft elevation taking it to sea level
Old Nov 8, 2023 | 09:11 AM
Pitbull2o08's Avatar
Hello!
I think I’ll be buying a car that’s currently built and living in elevation it’s whole life, at about 4700 feet now. I live at sea level.
I plan on cruising it home and enjoying it. I understand it will likely lean out. But is there something I can do on the road to correct this quickly or just baby it until it gets home then rejet and retime it after?
It’s a 400g block with a bore and 455 rotating assembly done years ago.
Old Nov 8, 2023 | 09:16 AM
I wouldn't worry about it. Just buy it and drive it home. Once you have her back home you can do a tune up and get her ready to go at sea level.
Old Nov 8, 2023 | 10:46 AM
ok thanks!
Old Nov 8, 2023 | 07:27 PM
IF the person who built the car optimized jetting for altitude, it will be lean at sea level. Just be careful and check the plugs after driving it a while at sea level. Bleached white plugs indicate too lean. Of course, I suspect that most people have no clue how to properly jet a carb, so chances are it still has the out of the box generic jetting. I ***-U-ME we are not talking about a late 70s-early 80s car where GM sometimes used altitude-calibrated carbs for emissions reasons. And again, this would assume the car was originally purchased and delivered at altitude.
Old Nov 9, 2023 | 06:06 AM
yeah it’s an original 4000ft car in 1969. So we will see. It will live its life at sea level here on out so I will check plugs and have jetting optimized along with timing
Old Nov 9, 2023 | 07:32 AM
I'm not certain the following quote/information is 100% correct, but I've read this in several locations on the Internet:
A rough estimate is one to two jet size reduction for every 1,000-foot elevation increase.
Old Nov 9, 2023 | 09:06 AM
GM did not use altitude-calibrated carbs in 1969, so if the jetting hasn't been changed from stock, you have nothing to worry about. Of course, E10 runs lean as compared to 1969-vintage gasoline.
Old Nov 9, 2023 | 10:12 AM
thanks Joe. Do you know the factory jets needed? Would a 455 rotating assembly and bore (bringing to over 400ci) change the required fuel amount and timing? How would I go about getting a baseline at home and adjusting from there?
rustyroger
Sep 28, 2015 12:53 PM
stevengerard
Dec 14, 2012 02:48 PM
TenMidgets
Jul 6, 2012 08:03 PM
theoldsrocket
Feb 12, 2011 05:47 PM
ralsy
Dec 6, 2010 08:14 AM
