Building 67 400 Engle 22-25
I think when I rebuild my 67 400 with a manual trans I am going to go with a Mondello or Engle 22-25 with the 108 LSA. What else do I need in the valve train dept to make this functional?
I'd use an adjustable valvetrain no matter what.
And that cam will work but the higher duration Mondello/Engle stuff has tendency to be a bit noisy, like sewing machine.
You now have a modern piston available for that engine too.
Introductory offer for the pistons is $645.00 shipped. That's pistons, pins, clips AND rings. They're is a post on here with pics.
Use the Comp adjustable pieces, 4843, 4542, I believe and the roller tip rockers. Try not order the whole kit as they normally come with the wrong pushrods.
Here is a link to the pistons I bought from cutlassefi.
https://classicoldsmobile.com/forums...e-pistons.html
507OLDS
November 12th, 2012 06:36 AM
