Building 67 400 Engle 22-25
Old Dec 26, 2017 | 10:47 AM
NotDads442's Avatar
I think when I rebuild my 67 400 with a manual trans I am going to go with a Mondello or Engle 22-25 with the 108 LSA. What else do I need in the valve train dept to make this functional?
Old Dec 26, 2017 | 12:20 PM
cutlassefi's Avatar
I'd use an adjustable valvetrain no matter what.
And that cam will work but the higher duration Mondello/Engle stuff has tendency to be a bit noisy, like sewing machine.
You now have a modern piston available for that engine too.
Old Dec 26, 2017 | 12:31 PM
NotDads442's Avatar
How much are the slugs and do you have any part numbers on the valve trains components?
Old Dec 26, 2017 | 12:37 PM
cutlassefi's Avatar
Introductory offer for the pistons is $645.00 shipped. That's pistons, pins, clips AND rings. They're is a post on here with pics.
Use the Comp adjustable pieces, 4843, 4542, I believe and the roller tip rockers. Try not order the whole kit as they normally come with the wrong pushrods.
Old Dec 26, 2017 | 12:50 PM
NotDads442's Avatar
Wrong length pushrods? Do I want the oil restricted pushrods that Mondello and others offer?
Old Dec 26, 2017 | 02:46 PM
cutlassefi's Avatar
I use a restricted .120 Wall 5/16” pushrod in virtually all my builds, never an issue. I offer them as well.
Old Dec 27, 2017 | 04:00 PM
Kennybill's Avatar
Here is a link to the pistons I bought from cutlassefi.
https://classicoldsmobile.com/forums...e-pistons.html
p518
Mar 16, 2013 06:16 AM
507OLDS
Nov 12, 2012 06:36 AM
RetroRanger
Oct 26, 2012 07:06 PM
oldzy
Jun 1, 2011 05:02 PM
Daverd
Mar 20, 2011 03:12 PM
