Break intake manifold loose
Old Nov 10, 2017 | 05:01 PM
jonesolds442's Avatar
Hello,
Working on my '70 442 - replacing intake gasket, even though rebuild was within 15k miles. Having difficulty getting the manifold to break loose (still in car). I can't seem to get the crowbar, or equivalent, anywhere to get some good leverage. Any tips on this? Also, is there a suggested solution that can be applied and will dissolve the gasket over time; similarly to breaking rusted hardware loose? I did the intake on my Rallye a few years ago and that thing broke loose a lot easier than the 442.
Thanks in advance.
Old Nov 10, 2017 | 05:56 PM
Take the water neck off and pry up through the thermostat hole.
Old Nov 10, 2017 | 06:41 PM
Yellowstatue's Avatar
Or if the lift loop is still on the left side, put a pry bar through it and lift.
Old Nov 11, 2017 | 11:51 AM
If the lift loop is still in place, that means that the intake is still bolted to the block.
I usually use a large flat blade screwdriver in the front rubber end seal, between the intake and the block. That surface is not as critical as the intake to head surfaces, and I use RTV there instead of the rubber anyway.
Old Nov 11, 2017 | 09:48 PM
I was thinking about that after I went to bed yesterday and realized that too!!
Old Nov 12, 2017 | 06:23 AM
Bfg's Avatar
Bfg
I often go to bed with a problem and wake up with a solution at hand!
Old Nov 12, 2017 | 08:38 AM
lemoldsnut's Avatar
Make darn sure you have all the bolts out. The method Joe stated works great. However, it works so well that if you leave a bolt in you will break the intake. So double check. (you know how I know this right?)
Larry
kyleg
Ninety-Eight
Jun 11, 2016 04:32 PM
shamusj
Dec 18, 2014 09:28 AM
ztim
Jul 10, 2009 05:28 PM
scrappie
Apr 9, 2008 05:12 PM
Old Whitey
Nov 25, 2006 08:19 PM
