big car aircleaner base-HELP HELP
Old Nov 12, 2012 | 07:43 AM
therobski's Avatar
Guys I spent alot of time fabbing this dual snorkel air cleaner for my 64 F-85 build and never figured in I would have hood clearance issues. Questions is did any of the big cars use a drop base air cleaner? ( for a Q-jet so I'm thinking what, 66 on up?) The one pictured is from a 66 Starfire ( took the snorkel off of one and fabbed into another) and it did not have a drop base. Maybe a Toro, Eldo?
Old Nov 12, 2012 | 08:32 AM
This is what I had to use on my car for hood clearance.
http://compare.ebay.com/like/3506280...Types&var=sbar
Old Nov 12, 2012 | 08:36 AM
therobski's Avatar
You can buy those new from Paragon Corvette for $65.00, that is what I bought for my 67 however they are not wide enough. The big car are 14 inches wide.
Old Nov 12, 2012 | 09:36 AM
11971four4two's Avatar
MOTORHEAD
http://www.summitracing.com/parts/edl-1221
Could you use the base from something like this one. They are $30 or so
Old Nov 12, 2012 | 09:41 AM
therobski's Avatar
I need a 14 inch drop for a Q-Jet, I may call Summit and see if they have one thanks for the tip.
Old Nov 12, 2012 | 02:45 PM
therobski's Avatar
1971-442 It looked up the foot notes and they claim it will work with a Qjet. I am also running a Lokar throttle cable that has a bracket bolted to the back of the carb base. But if can get close I can fab it up a bit. Thanks for the tip.
Old Nov 12, 2012 | 05:00 PM
That base uses a 14" round filter that I recommend, and I believe you can use it with a rochester. I have one on my car but no rochester carb to try it on. See if the one on your 67 will fit under the twin snorkle, I'd be curious to know.
Old Nov 12, 2012 | 05:11 PM
therobski's Avatar
See what happens! thanks.
Old Nov 13, 2012 | 02:30 PM
ThePackRat's Avatar
Big Daddy No Bucks
Originally Posted by therobski
a 14 inch drop
I think you might have your work cut out for you in finding one of those.
Old Nov 19, 2012 | 01:23 PM
Kolby66's Avatar
I believe the Toro's had a drop air cleaner as well as a lower intake, to make everything fit. Trans Ams base drops also to allow clearance for the hood scoop. Hope this helps.
Old Nov 23, 2012 | 07:59 AM
Bill in NC's Avatar
This was a quick test fit on my 65. I believe this is a 66? Toro cleaner and uses the "standard" 14x3 air filters. I actually gained hood clearance over the aftermarket moroso air cleaner assy. Q-jet drop base, recess in the rear for the distributor, dual snorkels. I know a guy who has a few more of these for sale.
Old Nov 24, 2012 | 08:06 PM
DeltaPace77's Avatar
My car originally came with a 403 engine, which is known to have a drop base air cleaner. Has a 455 in it now, with a tuned Q-Jet, and the modified original air cleaner. Looks like "Bill in NC's" and good idea grabbing fresh air, before the hot radiator. No one hears you coming either.
Jul 18, 2012 05:35 AM
OldsManNJ
Dec 2, 2011 08:44 AM
dschallock
May 12, 2011 09:01 AM
charlierogers
Jan 1, 2011 02:33 AM
The Stickman
Jul 15, 2009 06:02 AM
