Big block ID numbers
I recently bought a 1950 Ford Coupe with a what I was told is a Olds engine. The numbers on the back of the block are CFD 577476 4 1/8. I woujld like to know more about the engine. Thanks Larry
Hi Larry
those numbers do not look like Olds Casting Numbers
If you take a photo of the engine and email it to me I can help narrow it down for you.
jdorour@bellsouth.net
Serouisly Confused
My 71 442 convertable:
The ID plate is located on the firewall under the hood in front of the divers position.
It reads: ST71 34467LAN415816 Body paint
TR989 68 E
05D
Ok I understand from the guys helping out here that the LAN means it was produced in Michigan (Lansing) But what is the body paint color I think it was the Brown but since someone before me sprayed flat black over the entire car i don't know. The engine numbers on top of the timing chain cover read as 396021 F and the thremostat intake reads with raise numbers as 36080 and on the by-pass outlet 020.
Any help is greatly appreshated be cause all I am truly lost. As soon as I can get her airborne I'll have rear end tube numbers, and sooner or later I'll have the numbers off the back of the block.
The passenger side head has these number raised on it as well. 884 548 in the center and near the front the numbers 28??
I just wish I knew what I have.
Thanks tons all. Chip
71 442 conv.
TR989 68 E
05D
71 442 conv.
BigBertha442
Jul 9, 2009 11:18 AM
