Big block ID numbers
Old Jun 24, 2007 | 03:12 PM
tobipaint's Avatar
I recently bought a 1950 Ford Coupe with a what I was told is a Olds engine. The numbers on the back of the block are CFD 577476 4 1/8. I woujld like to know more about the engine. Thanks Larry
Old Jun 24, 2007 | 06:28 PM
Redog's Avatar
I have some info on that, but I need the casting number on the front of the block, right in front of the manifold
Old Jun 24, 2007 | 08:05 PM
tobipaint's Avatar
The number on the front of the intake manifold is 58j677.
Thanks Larry
Old Jun 30, 2007 | 10:43 AM
jdorour's Avatar
Hi Larry
those numbers do not look like Olds Casting Numbers
If you take a photo of the engine and email it to me I can help narrow it down for you.
jdorour@bellsouth.net
Old Jun 30, 2007 | 10:48 AM
jdorour's Avatar
I guess my info is not complete...
Check out this thread " 394 casting #'s ??? "
Old Jul 7, 2007 | 03:34 PM
59-59-59's Avatar
Of all the 394's I have rebuilt / torn out (15 - 20 of them), ALL had the 4 1/8 casting in the block, referring to the bore ( 394 )
Old Jul 7, 2007 | 05:41 PM
tobipaint's Avatar
Big Block ID Numbers
What is a running 394 worth. I have someone interested but need a ballpark value.
Thanks Larry
Old Jul 11, 2007 | 10:48 AM
Chip's Avatar
Serouisly Confused
My 71 442 convertable:
The ID plate is located on the firewall under the hood in front of the divers position.
It reads: ST71 34467LAN415816 Body paint
TR989 68 E
05D
Ok I understand from the guys helping out here that the LAN means it was produced in Michigan (Lansing) But what is the body paint color I think it was the Brown but since someone before me sprayed flat black over the entire car i don't know. The engine numbers on top of the timing chain cover read as 396021 F and the thremostat intake reads with raise numbers as 36080 and on the by-pass outlet 020.
Any help is greatly appreshated be cause all I am truly lost. As soon as I can get her airborne I'll have rear end tube numbers, and sooner or later I'll have the numbers off the back of the block.
The passenger side head has these number raised on it as well. 884 548 in the center and near the front the numbers 28??
I just wish I knew what I have.
Thanks tons all. Chip
71 442 conv.
bocoogto
Aug 26, 2023 06:09 PM
olds4life
Feb 9, 2010 08:48 AM
davepnola
Dec 18, 2009 05:50 AM
NEWOLDSMAN
Nov 17, 2009 12:19 PM
BigBertha442
Jul 9, 2009 11:18 AM
