big block 455 fuel pump
Old Jan 1, 2018 | 06:14 AM
dal442's Avatar
greetings all and happy new year.....
seems the fuel pump on my 442 has decided to" check out " for the scrap heep.
i can only guess the diaphragm has let go.....and since the ambient temp. outside here in northwest indiana is 6 below this morning, i'm not in a big hurry to be laying on my back and making a changeout.
just need to get some opinions on brands of pumps you fella's are using, or have replaced the oem (2) line in/ out. i'm guessing a 5-6 psi pump for an oem setup is appropriate..... suggestions ??
dal442
Old Jan 1, 2018 | 08:46 AM
oldsmobiledave's Avatar
Carter
Stock engine and fuel system requires only a stock replacement pump. I've used Carter pumps with no issues for that application.
Old Jan 1, 2018 | 09:07 AM
Yep. Your local auto parts store should have it. Mine had to get it from the warehouse, which took a day, which was faster than buying online and having it shipped.
Old Jan 2, 2018 | 03:49 PM
Airtex 40736. Stock replacement for W-30 and 455 high output Toronado. It’s pretty of pump for a stout 455, especially for a $40 pump.
bocoogto
Aug 26, 2023 06:09 PM
cfair
Dec 11, 2017 08:31 PM
bspaulding
Sep 3, 2016 04:15 PM
Octania
Apr 7, 2016 02:51 PM
HonestDave
Aug 31, 2012 01:23 PM
