Battery Voltages
Battery Voltages
I thought I'd give my 57 Olds battery a voltage check with the car ignition off verses on.
Off: the battery is 12.7V
On: the battery registers 14.5V
The battery seems to be in the "Good" range with the engine off. However, I am not so sure about the 14.5V with the ignition on. Is this voltage too high or within an acceptable charging range?
59Olds98
December 25th, 2013 08:20 AM
w-30dreamin
January 9th, 2010 03:19 PM
