Battery Voltages
Old Sep 20, 2009 | 02:29 PM
Dan Wirth's Avatar
Battery Voltages
I thought I'd give my 57 Olds battery a voltage check with the car ignition off verses on.
Off: the battery is 12.7V
On: the battery registers 14.5V
The battery seems to be in the "Good" range with the engine off. However, I am not so sure about the 14.5V with the ignition on. Is this voltage too high or within an acceptable charging range?
Old Sep 20, 2009 | 03:21 PM
citcapp's Avatar
The 14.5 is right on the money
Old Sep 20, 2009 | 04:32 PM
Dan Wirth's Avatar
Thanks for the reply citcapp.
Dan
Old Sep 21, 2009 | 05:08 AM
Lady72nRob71's Avatar
With the lights and heater fan on high, the reading should be no lower than 13.5 or thereabout. 14.5 is normal as said.
Old Sep 21, 2009 | 08:20 AM
Dan Wirth's Avatar
You know, this is exactly the kind of information that makes this forum a winner.
Thank you,
Dan
Texas442
Mar 28, 2013 07:13 PM
b350m
Aurora
Aug 3, 2011 03:04 PM
w-30dreamin
Jan 9, 2010 03:19 PM
bermuda
May 18, 2006 11:38 AM
