Are aluminum roller rockers noisy??
I have a set of full roller aluminum rocker arms and I have a slight sewing machine noise and wondered if they would make noise even if properly adjusted?
You need to go to the rocker arm manufacturers specs and see what the setting needs to be. IF you have a really agressive cam, yes they will make noise! I have Harland Sharpes on mine and they make a little noise.
A mechanical flat tappet cam is considered a 'solid' cam, which needs .015 - .030 clearance between valve and rocker arm, and will sound like a sewing machine!
Hope you've the cam card which gives you that setting for that cam, as they should be checked about every 5000 miles.
![Wink](https://classicoldsmobile.com/forums/images/smilies/wink.gif)
