72 455 Cutlass fan blade, clutch & shroud help needed
Old July 20th, 2017, 03:58 PM
Eastflorida's Avatar
I'd like to get advice on the best combination of fan blade and fan clutch combo.
Currently has a fixed blade with no clutch and the fan appears to be too small. Seems to be a 17" fan but with over 2.5" clearance between the blade and the shroud.
Another issue is that the bottom of the shroud appears to have been cut out. Any fix or simply buy a new shroud? Does this look right for the proper fit or is this another patchwork effort?
Looking for advice to get this corrected and operating well.
See pics... Thanks!!
Eastflorida is offline
Old July 20th, 2017, 04:16 PM
The part number on that fan comes up as an aftermarket flex fan in a web search, so it's no wonder that it doesn't fit the shroud properly.
Those things don't move nearly enough air, so it's a good thing you are looking to replace it.
And that shroud definitely doesn't look the same as the one on my car (AC car same as yours).
I would look for a factory fan and shroud, then get a good quality clutch from the auto parts store.
Fun71 is online now
Old July 20th, 2017, 06:04 PM
72 Olds CS
RetroRanger's Avatar
all of what ken said
RetroRanger is offline
Old July 20th, 2017, 06:16 PM
Thanks, I had the same opinions as you. Where can I find a factory type fan and are the shrouds different for A/C vs non-A/C cars? Looks like only one style. I get the impression what I have is a patch fix...
Old July 21st, 2017, 06:07 AM
Are you having temp problems?
oldcutlass is online now
Old July 21st, 2017, 01:23 PM
Post in the Parts Wanted section. We have quite a few folks who part out cars and/or have a stockpile of parts they will sell.
Fun71 is online now
RandyS
July 6th, 2021 07:45 PM
Bee Saint Louis
July 5th, 2019 08:58 PM
jpc647
December 16th, 2016 06:21 AM
toymobile
June 9th, 2015 03:41 AM
Quick Reply: 72 455 Cutlass fan blade, clutch & shroud help needed
