70 442 w30 vacuum line set up
Old August 21st, 2015, 07:59 PM
cdoering's Avatar
I recently bought some new color stripped hoses to replace vacuum lines. I am stumped on one of the hoses. I do have the olds book that shows the layout location (page 404414). Most of you have done this know what page I;m taking about. The house is question is the hose that goes to the modulator vacuum? This house connects (5.5 inch long) to the T connector which connects to the the T.V.S which connects to the manifold vacuum. I cant figure where to connect the hose that is suppose to go to the modulator vacuum. What is this and where is it located.
I even looked at the ram air cleaner set up diagram to see if it showed on this and nothing can be seen.
I am stumped.
Chris
cdoering is offline
Old August 24th, 2015, 03:27 PM
BlackGold's Avatar
The hose for the modulator attaches to a steel pipe which lies along the top of the right-side valve cover and runs down to the modulator on the transmission (where it is attached to the modulator with a very short hose). See section 7 page 115 of the Product Information Manual. It doesn't show the 5.5" hose, but it does show the steel pipe.
BlackGold is offline
Old August 25th, 2015, 05:02 PM
cdoering's Avatar
thanks for the tip, I'll look for this. Currently I dont have the steel pipe running from trans. When I was judging at the olds national in WI last month, I dont remember seeing any 70 442 W30 with this as well.
Chris
cdoering is offline
Old August 27th, 2015, 03:15 PM
BlackGold's Avatar
Every Olds with a TH350 or TH400 has the steel pipe. It's thinner than a vacuum hose, because the ends fit inside a vacuum hose.
September 29th, 2014 01:12 AM
Del70
November 15th, 2013 02:24 PM
davepnola
December 2nd, 2010 09:00 PM
Flye
July 31st, 2009 04:03 PM
68conv455
May 20th, 2008 02:03 PM
Quick Reply: 70 442 w30 vacuum line set up
