66 Delta88 425UHC Super rocket
Old Nov 12, 2008 | 12:26 AM
WEBBISH's Avatar
Question 66 Delta88 425UHC Super rocket
I just bought this 66 2Dr ht for 500.00 needs paint and inteior runs great except for the smoke that comes out of the drivers side valve cover breather at a stop light it looks like she is on fire from the smoke. Any suggestions maybe just a bad breather? Any help would be greatly apprciated.
Old Nov 12, 2008 | 04:45 AM
Oldsguy's Avatar
Past Administrator
Welcome to our site. I doubt it is just a bad breather, if the smoke it coming out the breather is passing gas (not a joke). Remember that engine is more than likely 42 years old.
Old Nov 12, 2008 | 05:06 AM
Make sure your PCV valve is set up correctly. The engine vacuum should draw the crankcase vapors out of your valve cover and back into the engine if it is functioning properly. If the car is smoking to bad you might have to do some work to the engine.
Old Nov 12, 2008 | 08:18 PM
WEBBISH's Avatar
Great site I'm glad I found it. I bought this car from the original owner he bought it in Dec. 65 and I got it Aug. 2008 it is all oridginal #'S matching engine trans and rear end. It runs strong and doesn't smoke except for the breather so thanks for the info Cause I'm sure I will have plenty of Questions. I'm doing brakes and new U-joints tomorrow and try a new PCV also. I've never seen frt drum brakes before they look like new bareings and seem smooth so I will waite on those.
Mak
53
Nov 18, 2011 04:23 PM
EdsDelta
Jul 22, 2004 11:46 AM
CTWalneck
Jan 12, 2004 12:32 PM
CTWalneck
Jan 12, 2004 12:30 PM
<CTWalneck>
Jan 12, 2004 12:05 PM
