65 A Heads
Old Jan 20, 2016 | 05:33 AM
craig442's Avatar
65 A Heads
What is the difference between the 65 "A heads" stamped with a "V" code and the 65 "A heads" stamped with a "N" code ? All other numbers are the same.
Thanks!
Old Jan 20, 2016 | 09:16 AM
Octania's Avatar
I believe the V is for 442 engines
the N is for run of the mill Big Car engine.
I vaguely recall M vs N being high compression vs lower compression.
Chassis Service Manual section 0 should have all that info.
Later, we also have a T suffix for Toronado... if you find Toronado A heads, that would be quite a score, for the elusive 1965 Toronado!
64 CUTLASS KEN
Dec 7, 2020 06:43 AM
olds4life
Dec 25, 2012 12:56 AM
Oldsmaniac
Nov 1, 2010 06:37 PM
gearheads78
Nov 10, 2009 09:31 PM
DarkStar
Oct 21, 2009 07:35 AM
