455 street/ strip motor build
Hi, looking for some ideas on what would be the best combination for building my engine. I am starting with a '71 Toronado engine. I want to keep the build streetable, as it will see more cruising than track time, but I also want to have something that could be run at the track. I was thinking of a mid 9 compression ratio with .03 forged pistons . I am planning on using the repop W-30 intake , quadrajet, and wz exhaust manifolds with 2 1/2 pipes. I would appreciate some help on selecting the best cam for this engine. The engine will be going into a '72 cutlass coupe.
my opinion
Skip the repo W-30 aluminum intake & put a Performer on it. You will need to decide on gear ratio, tire size & converter when picking your cam so that you have a well balanced driveline.
??Turbo 400 with heavy duty sprag and shift kit would be enough for the tranny. 2800 stall converter go with a lift on cam around 496 maybe a tad more. Use H/S roller rockers. As oldsmobiledave said get a performer intake. Then this motor will be in the twelves and streetable.JMO
Might as well go with a normal build that is bored .030-.060 over, find a nice modular crank that doesn't need much work and find yourself a good set of moderately worked iron heads or try and find some used aluminum heads. Go with a good set of refurbished oem rods unless you want excess of 500hp and decent forged Pistons in the 10:1 range. You might as well take advantage of today's technology and use a custom ground hydraulic roller hydraulic cam and valvetrain. Top it with a performer or performer rpm and get an electronic ignition by msd and you should have a nice street/strip engine!
How would I go about selecting the proper size for a hydraulic roller cam? Is one manufacturer better than the other? This is going to be my first time going into a build using one and I am trying to learn so I don't end up with a mismatched mess. My projected specs for my 455 will be arias forged pistons (compression around 9.5-9.6), reconditioned stock rods, total seal rings , large valve g iron heads (some bowl work and polished) stock nodular crank . I am looking to get around 450hp out of the build.
I can help, shoot me an email if you like at fastone01@hotmail.com Thanks
To get the best cam, contact Mike Jones or fill out the cam recommendation sheet (easy), and he'll send you the proper cam specs. Good luck.
http://jonescams.com/
Cutlassefi is building mine currently. I'm sure he will update the progress on here. It's a 550+ hp build. I'd call or message him and you could dial my combo down a few notches for A good streetable engine!
<johnny5>
Cars Wanted
Aug 25, 2005 12:46 PM
