455 street/ strip motor build
Old Nov 10, 2015 | 04:48 PM
yellowrocket's Avatar
Hi, looking for some ideas on what would be the best combination for building my engine. I am starting with a '71 Toronado engine. I want to keep the build streetable, as it will see more cruising than track time, but I also want to have something that could be run at the track. I was thinking of a mid 9 compression ratio with .03 forged pistons . I am planning on using the repop W-30 intake , quadrajet, and wz exhaust manifolds with 2 1/2 pipes. I would appreciate some help on selecting the best cam for this engine. The engine will be going into a '72 cutlass coupe.
Old Nov 10, 2015 | 04:53 PM
oldsmobiledave's Avatar
my opinion
Skip the repo W-30 aluminum intake & put a Performer on it. You will need to decide on gear ratio, tire size & converter when picking your cam so that you have a well balanced driveline.
Old Nov 10, 2015 | 05:04 PM
Thanks, looking at 3.23 gears ,400 turbo and converter built to w-30 spec(og or ow can't think of it off the top of my head) ,and 225 70 15 tires
Old Nov 10, 2015 | 06:00 PM
wr1970's Avatar
??Turbo 400 with heavy duty sprag and shift kit would be enough for the tranny. 2800 stall converter go with a lift on cam around 496 maybe a tad more. Use H/S roller rockers. As oldsmobiledave said get a performer intake. Then this motor will be in the twelves and streetable.JMO
Old Nov 11, 2015 | 04:28 PM
madmax442's Avatar
Might as well go with a normal build that is bored .030-.060 over, find a nice modular crank that doesn't need much work and find yourself a good set of moderately worked iron heads or try and find some used aluminum heads. Go with a good set of refurbished oem rods unless you want excess of 500hp and decent forged Pistons in the 10:1 range. You might as well take advantage of today's technology and use a custom ground hydraulic roller hydraulic cam and valvetrain. Top it with a performer or performer rpm and get an electronic ignition by msd and you should have a nice street/strip engine!
Old Jan 6, 2016 | 06:04 PM
How would I go about selecting the proper size for a hydraulic roller cam? Is one manufacturer better than the other? This is going to be my first time going into a build using one and I am trying to learn so I don't end up with a mismatched mess. My projected specs for my 455 will be arias forged pistons (compression around 9.5-9.6), reconditioned stock rods, total seal rings , large valve g iron heads (some bowl work and polished) stock nodular crank . I am looking to get around 450hp out of the build.
Old Jan 6, 2016 | 06:07 PM
sorry if this seems redundant , I am just wanting to build this engine correctly and don't want to blow a whole lot of money on the wrong parts.
Old Jan 6, 2016 | 06:32 PM
cutlassefi's Avatar
I can help, shoot me an email if you like at fastone01@hotmail.com Thanks
Old Jan 6, 2016 | 07:22 PM
70cutty's Avatar
Beer Connoisseur
You can't go wrong with Cutlassefi, great guy to deal with. He can also help you with the rest of the combo.
Old Jan 7, 2016 | 09:06 AM
Backstrom's Avatar
Amen on that!!
Old Jan 7, 2016 | 04:55 PM
jeure's Avatar
+1 on cutlassefi. One of the very best around.
Old Jan 17, 2016 | 06:46 AM
shiftbyear's Avatar
To get the best cam, contact Mike Jones or fill out the cam recommendation sheet (easy), and he'll send you the proper cam specs. Good luck.
http://jonescams.com/
Old Jan 22, 2016 | 02:19 AM
AK71CutlassS's Avatar
Go with CutlassEFI he knows his Olds Engines
Old Jan 22, 2016 | 03:37 AM
EightballZ's Avatar
..what he said
Old Jan 23, 2016 | 05:38 AM
madmax442's Avatar
Cutlassefi is building mine currently. I'm sure he will update the progress on here. It's a 550+ hp build. I'd call or message him and you could dial my combo down a few notches for A good streetable engine!
lilgiff
Oct 20, 2012 10:15 PM
drjr56
Aug 29, 2012 11:54 PM
1940bowtie
Jun 17, 2007 09:22 AM
anthonylenhardt
Mar 28, 2007 11:30 PM
<johnny5>
Cars Wanted
Aug 25, 2005 12:46 PM
