65 400
Old May 2, 2022 | 06:50 AM
65droptop's Avatar
65 400
Looking for a good cam for my 65 400 build. My machine shop says he can only find a factory cam, due to no cores available for a custom grind. Any ideas?
Old May 2, 2022 | 07:31 AM
edzolz's Avatar
Your 65 400 will be a 45 degree cam and there are numerous cam grinders that can grind any option you want or need. Get a machine shop that is willing to do a little research.
Old May 2, 2022 | 09:00 AM
65droptop's Avatar
If you have done any research lately, you would know that cam cores for grinding are scarce, so, instead of telling me to find a machine shop that will do research, assuming they haven’t, how about you just say, hey, so and so will do it.
Old May 2, 2022 | 09:02 AM
cutlassefi's Avatar
If it’s a large lifter 400, and it’s most likely a 39° Block. And yes most people are out of Cores today.
Old May 2, 2022 | 09:16 AM
I may be confused, but the OP says he has a '65 400ci, which by all the info I know of would have the 45° lifter bank angle, and the smaller .842 lifter bore.
Old May 2, 2022 | 10:29 AM
Duh's Avatar
Duh
Correct for "B" block (1965)
Old May 2, 2022 | 02:06 PM
cutlassefi's Avatar
You’re right. They changed in 66 correct?
Old May 2, 2022 | 03:05 PM
Correct. The '66 and '67 400's had the 39° lifter bank angle, .921 lifter bore, and bigger valves in the "C" heads. The 400ci motors in the 442's changed again in '68. The '68 and '69 400ci's were made from the same raw block as 455's. These 400's had a smaller bore and longer stroke than the '66's and '67's to achieve the same displacement. They still had the 39° lifter bank angle, but went back to the smaller .842 lifter bore.
Old May 2, 2022 | 03:41 PM
cutlassefi's Avatar
The 68-69 were a SIMILAR raw block vs the 455, not the SAME raw block. If they were the same then you’d be able to bore a 400G to 4.125, and you can’t.
Just an fyi.
Old May 2, 2022 | 04:04 PM
Just an fyi.
Mark - You are correct! I misinterpreted the meaning of "type" found in the attached chart that Joe P. posted. I thought when the chart said '68 and '69 400's were derived from a 455 "type" block, that it meant "the same as". Thanks for the correction.
Old May 3, 2022 | 08:22 AM
65droptop's Avatar
john at delta camshaft in tacoma washington says he can do a regrind with lifters for under 200 bucks, that seems cheap to me. anyone ever deal with them?
Old May 4, 2022 | 08:33 AM
edzolz's Avatar
The internet always amazes me with what can be found with a little research.
65droptop
Mar 26, 2022 03:21 PM
Rallye469
Dec 28, 2021 11:25 AM
Toms65
Jan 6, 2018 06:15 PM
67Rocket
Feb 13, 2017 08:48 AM
Bfg
Jun 28, 2016 04:53 AM
