65 400 question
65 400 question
What is the difference between a 65 400 block and a 66-67 400 block? Any disadvantages of using a 65 block? Was thinking about using 69 C heads with the 65 block. Thanks
I think it's the lifter bore diameter and angle. I know the 67 block is .921" bore and 39º angle and I think the 65 is .842" bore and 45º angle.
The 65 block has the more common and cheaper lifters but you would need to have a cam custom ground for 45º, which I have read here is simple (just tell the company you need 45º) and only slightly more cost that an off-the-shelf cam.
The heads will bolt up with no issues but you may need to verify the push rods don't rub on the holes due to the different bank angle. I have heard it's easy to open the holes to prevent push rod contact.
Does anyone know how much the pushrod holes have to be opened up? For a basically street engine, do the C heads perform much better than the early A heads that are currently on this motor? Thanks again
