455 swap help
Old Nov 12, 2007 | 04:00 PM
SPYDER's Avatar
455 swap help
hey everyone .helllppppp, lol..its a 1980 cutlass salon, with a 3 speed manual on the floor.........................what do i need to bolt the 455 up to the 3speed, im pretty sure its a saignaw, oh, and, its a buick 455 out of a 75 riviera gs, thanks
Old Nov 12, 2007 | 11:54 PM
dar83501
Guest
Posts: n/a
you're going to need to find a turbo-400 transmission to hold back a 455..even if it is a buick motor i'd say.
Old Nov 13, 2007 | 09:48 AM
The Dearborn (aka Ford Toploader) three speed was the factory base trans behind the big block in the 68-70 442s. This particular car probably has the weak Saginaw three speed.
Old Nov 13, 2007 | 02:22 PM
SPYDER's Avatar
i think it has a turbo 400 on the 455.......but id like to keep the car manual, i was told a saiginaw would take around 400hp for a bit before it died...not true?....then id have to swap....m22 maybe.....why make a rare factory manual car an auto.....
long term plans = new trans, 9 inch,aluminum heads ect....but id just like to get it running in there with the stock heads and what 250 hp or whatever it is
Old Nov 13, 2007 | 02:55 PM
J-(Chicago)'s Avatar
Seasoned beater pilot.
I don't know about Buick motors, but I believe Oldsmobile 455 blocks after 1972 do not have a hole for the ball pivot in the back of the block, and therefore must be machined to accept a manual transmission.
Old Nov 13, 2007 | 03:37 PM
If you have a Buick 455 with a TH 400 then you will have to get the crank machined and install a clutch on your flywheel. I believe the flywheel is different for a manual transmission.
Old Nov 13, 2007 | 04:24 PM
I don't know if Buick drilled cranks for the pilot bearing or not, but a manual trans flywheel is definitely required. An automatic uses a flexplate.
Daniel Marsh
Dec 5, 2014 03:25 PM
Limey
Apr 15, 2013 10:45 AM
'69CutlassVert'
Aug 25, 2011 07:19 AM
70cutman
May 22, 2011 09:03 AM
dgreen
Mar 26, 2010 10:19 AM
