455 rebuild need specs
Old Sep 27, 2012 | 10:12 AM
SRV8's Avatar
Smile 455 rebuild need specs
Hello my name is Joerg from Germany,
I'm new here and need some help from people who know more than me about this 455 engine.
I want to rebuild an 1971 455 out of an 98.
Therefore I need the original specs of the crank and the allowed specs within standard size (bearings) of main's and rod's journals.
And I plan to drill a hole in the crank for a pilot bearing because perhaps I want later install an manual transmission.
Therefor I need the dimension of the hole.
I plant to use the Edelbrock alu. heads to get more power.
Which pistons work good and are not to expensive to get around 10:1 compression.
And I want to install an roller cam which is good until 6000 rpm without losing low end torque which one would be o good choice.
I' bought oilresistors where I should use them (in which oil holes) for an street engine which has to show what it can (HV Oilpump and 8 qt oilpan I've also)
I hope that someone can help me out engine should go in the machine shop in 2 weeks.
Greetings from Germany Jörg
Old Sep 27, 2012 | 11:09 AM
dancutlass's Avatar
Welcome Jörg from a fellow German
There are a lot of great knowledgeable guys on here and I'm sure you will find the information you are searching for!
Take a look at the Big Block section on this site, I guess there are several 455 builds described, with cam specs and recommendations and everything else you need! Sometimes with dyno-numbers
Good luck!
Old Sep 27, 2012 | 04:09 PM
cutlassefi's Avatar
Agreed, you'll find plenty of info here. Check out some of my builds and dyno sessions, they may be of some help.
I also offer custom grind cams, both flat tappet and roller.
"cutlassefi"
csouth
Oct 26, 2015 02:51 PM
bundy
Jan 29, 2014 04:59 PM
442dreamer
Aug 23, 2011 07:28 AM
Kidcutty
Jun 9, 2011 03:00 AM
neoinbiz
Oct 24, 2006 07:42 AM
