455 rebuild need specs
Hello my name is Joerg from Germany,
I'm new here and need some help from people who know more than me about this 455 engine.
I want to rebuild an 1971 455 out of an 98.
Therefore I need the original specs of the crank and the allowed specs within standard size (bearings) of main's and rod's journals.
And I plan to drill a hole in the crank for a pilot bearing because perhaps I want later install an manual transmission.
Therefor I need the dimension of the hole.
I plant to use the Edelbrock alu. heads to get more power.
Which pistons work good and are not to expensive to get around 10:1 compression.
And I want to install an roller cam which is good until 6000 rpm without losing low end torque which one would be o good choice.
I' bought oilresistors where I should use them (in which oil holes) for an street engine which has to show what it can (HV Oilpump and 8 qt oilpan I've also)
I hope that someone can help me out engine should go in the machine shop in 2 weeks.
Greetings from Germany Jörg
Welcome Jörg from a fellow German
There are a lot of great knowledgeable guys on here and I'm sure you will find the information you are searching for!
Take a look at the Big Block section on this site, I guess there are several 455 builds described, with cam specs and recommendations and everything else you need! Sometimes with dyno-numbers
Good luck!
Good luck!
Kidcutty
Jun 9, 2011 03:00 AM
