Casting #
Old Sep 27, 2012 | 09:52 AM
The Bug Man's Avatar
Casting #
First Olds project so I'm asking what may be silly ?'s to some of you. What do these casting #'s tell me about my 70 455 block? 396021F The heads are marked "E" Thanks
Old Sep 27, 2012 | 10:42 AM
Qwik71442's Avatar
Full-time Taxpayer
396021F = 455 Block
E Head = 1970 455 Head
Old Sep 27, 2012 | 11:10 AM
The same block casting was used from 1968 through at least 1974 (yeah, don't believe everything in the FAQ). The F casting did overlap with the Fa casting. As noted the heads are 1970 455 except W-30. You'll need to check the VIN derivative on the block to determine the exact year of the block.
Old Sep 27, 2012 | 12:07 PM
Casting #
If I'm not mistaken isn't the derivative # behind the a/c compressor bracket or the pwr steering bracket? Thanks for the help
Old Sep 27, 2012 | 07:00 PM
panther80's Avatar
Yes Sir, You may have to remove the brace to see that small flat spot that the vin derivitives are stamped.
55 Post
Jan 27, 2008 03:22 PM
kustom60dynamic_rick
Jun 16, 2007 05:14 PM
perro
May 2, 2007 02:39 PM
neoinbiz
Dec 25, 2006 06:07 PM
omega73
Aug 17, 2006 07:24 AM
