Casting #
The same block casting was used from 1968 through at least 1974 (yeah, don't believe everything in the FAQ). The F casting did overlap with the Fa casting. As noted the heads are 1970 455 except W-30. You'll need to check the VIN derivative on the block to determine the exact year of the block.
Casting #
