455 Oil Filter Adapter Options
Old Sep 6, 2017 | 12:21 AM
th3ric3m4n's Avatar
A picture is worth a thousand words, yes? I ran into a problem tonight when installing headers. The oil filter adapter on this 455 is angled such that a filter (I'm trying to use Wix 51258) cannot be screwed on without hitting one of the primary tubes.
It looks like I need an adapter that points straight down or possibly perpendicular to the block. What other compatible filter adapter designs did Oldsmobile make?
Old Sep 6, 2017 | 05:35 AM
Since you're running headers you apparnelty aren't too concerned with keeping the car completely original. Would an oil filter relocation kit work?
https://www.summitracing.com/parts/trd-1122
The space between your oil filter housing and the header is negligible. I don't even know if you could get a shorter filter in there. Hopefully others have ideas too.
Old Sep 6, 2017 | 06:39 AM
TripDeuces's Avatar
Is that from a Toronado? It seems to face forward too much. It should face straight down like the one in my pic. Although the one pictured is a oil cooler model the stock one would be shorter and still face down.
Old Sep 6, 2017 | 09:40 AM
RetroRanger's Avatar
72 Olds CS
pm sent
Old Sep 6, 2017 | 10:34 AM
Jpl67's Avatar
Rocket Racing in Wisconsin makes an oil filter adapter for better header clearance.
Old Sep 6, 2017 | 11:55 AM
You don't need an aftermarket adapter. You need to get rid of the Toronado oil filter adapter you have and install a correct RWD oil filter adapter.
Old Sep 6, 2017 | 12:24 PM
th3ric3m4n's Avatar
This block came from a pile of V8's in a junkyard, so I'm not sure what vehicle it was originally in. I seem to remember that I dated the block as an 1975. It did not have a Toronado pan with the indentation for the axle and also came with this angled oil filter adapter.
Old Sep 6, 2017 | 12:28 PM
Doesn't matter. That's STILL a Toro oil filter adapter.
Old Sep 6, 2017 | 03:23 PM
cutlassefi's Avatar
Correct. And the one from Rocket Racing will have the same position as the one you should be using, vertical. The only difference in the RR one is that it has slightly larger passages and doesn't have the relief valve.
Old Sep 6, 2017 | 08:44 PM
wr1970's Avatar
Do what Joe said and your problem is solved and the part is cheap.Ask around with a post in parts wanted forum and i bet someone has one.
Old Sep 9, 2017 | 03:14 AM
Ozzie's Avatar
As noted, the vertical adapter will likely resolve your fitment problem. You may also want to consider something to reduce heat transfer from that nearby tube.
Old Sep 27, 2017 | 01:11 PM
th3ric3m4n's Avatar
New vertical style filter adapter from RetroRanger installed and painted. The headers do not contact the oil filter anywhere. Excellent.
Old Sep 27, 2017 | 01:48 PM
72 Olds CS
Nice work, thanks Adam !!!
oldsonharmont
May 15, 2022 04:45 AM
72 Olds Project
Aug 14, 2011 12:41 PM
d2_willys
Aug 11, 2010 03:07 AM
tim72
May 6, 2010 10:58 AM
texasred
Jul 13, 2007 08:53 PM
