455 f block any good?
Old Oct 14, 2007 | 05:55 PM
shaks 442 clone's Avatar
is a 455 f block any good?
just wondering because i know someone selling one for $150 complete rebuild of course
and also
is $195 for a th400, b.o.p type, is that a good deal ?
the seller says it shifts into all gears no problem
Old Oct 15, 2007 | 08:12 AM
442Harv's Avatar
The block is STD bore, no crank. that is about the going rate. The trans, if it works, but has not been worked on for awhile, and will need to be checked, I think it is a little high. If it came out off a full size car and has a long tail shaft, it is way to much money.Not many guys want a long tail shaft, all looking for the short ones.
Old Oct 15, 2007 | 08:17 AM
442Harv's Avatar
One more thing, I see you live in Hayward, That is where I live also.May have parts for sale you may need? Don't have any blocks for sale right now, have a complete running 350, that came out off my VC, I would like to sell.
Old Oct 15, 2007 | 12:14 PM
whats been done to the 350 ?
how many miles?
a ball park on what your looking to get for it ?
Old Oct 15, 2007 | 01:26 PM
also the th400 is a short shaft
Old Oct 15, 2007 | 04:40 PM
442Harv's Avatar
The motor was in my 72 VC. I have owned the car abouit 4 years, it was running great. The only reason I took it out was to put in a 455. I do not know if it has been worked on or not? I took the valve covers off, and looked like some new rockers have been replaced. The car has about 38000, so I think 138000, and as good as it was running, I think I may have been worked on? It did not smoke or run bad. If a person need a engine, and did not have money to spend on a rebuild, I would have no problem putting it in as is. I would change the pan gasket, and front timming cover seal brfoe installing. I'm asking $325.
Old Oct 16, 2007 | 01:24 PM
i'll keep you in mind harv right now im not sure of what im going to do
these are a few of my plans
rebuild them motor i have right now (if its still useable)
upgrade to a 455 (but a lot more is into it then just dropping the motor in unfortuantely)
or finding a 350 already mildy built up
Old Oct 20, 2007 | 12:55 AM
so whats bad about this block again i just re read the first post by harv and didnt understand much of why i should stay away
Old Oct 20, 2007 | 06:12 AM
I think that block for $150 would be a good deal. Is it an entire engine or is it just a short block? I don't think you have to worry about damage to an engine that would prevent it from being non rebuildable. I just bought a 455 and TH 400 and was thinking about that; however, the chances that a street driven engine would throw a rod through the block or drop a valve into a piston are slim. Also, even if there is catastrophic damage to an engine pretty much anything can be repaired by a competent machinist these days. It is just a question of how much it would cost.
rjohnson442
Jun 14, 2013 08:03 AM
Caveman-455
May 6, 2012 06:36 PM
Oldwolf
Mar 1, 2010 12:36 AM
2TallCustomz
Apr 8, 2008 06:57 PM
shaks 442 clone
Mar 6, 2008 07:33 PM
