1971 455 out of a vista cruiser any good?
Old Mar 5, 2008 | 02:22 PM
shaks 442 clone's Avatar
does anyone know the compression ratio of this year 455?
is it worth buying?
and i just found out my 350 isnt worth rebuilding the crank has to many deep grooves and a lot of thrust play and it needs a sleeve.
Old Mar 5, 2008 | 03:01 PM
About 8.5:1. 1971 was the first year of reduced compression ratios to accommodate low-lead gas. The good news is that the G heads will have induction hardened valve seats.
is it worth buying?
The last 455 Olds block was cast in 1976. ANY 455 is worth buying.
Old Mar 5, 2008 | 11:27 PM
can the compression be steped up on a 71 or newer engine by simply changing the heads and pistons?
Old Mar 6, 2008 | 05:23 AM
Changing to the pistons without dishes will increase your compression. Summit's rebuild kit offers the pistons with reliefs that will be higher compression than any smogger engine. They are cast, but they aren't 8.5:1
Old Mar 6, 2008 | 06:12 AM
All Olds big block heads have the same 80-ish CC chambers (except for the 68-69 D heads that have a designed chamber of 72 CC). Note that as-cast the chambers tend to run about 83-84 CC. The compression ratio is varied by changing the size of the dish in the pistons. The factory low-compression pistons look like soup bowls.
Old Mar 6, 2008 | 07:31 AM
so with some nice flat top pistons what compression ratio would you think i would be close to?
Old Mar 6, 2008 | 07:45 AM
J-(Chicago)'s Avatar
Seasoned beater pilot.
To accurately calculate the static compression ratio of any engine, the following values must be known:
Bore diameter, stroke length, rod length, deck height, combustion chamber volume, cylinder head gasket compressed thickness, and cylinder head gasket bore diameter.
http://www.rbracing-rsr.com/compstaticcalc.html
Old Mar 6, 2008 | 08:09 AM
66 Olznut's Avatar
Ca's Only Official OLZNUT
These are the pistons out of my 400. I've never seen flat tops on an Olds until these. I was told these are the stock pistons. 400olds008.jpg
Old Mar 6, 2008 | 09:36 AM
W-31s also used flat top pistons from the factory.
Old Mar 6, 2008 | 07:33 PM
88 coupe's Avatar
Junior Member
........ so with some nice flat top pistons ........
You need to watch whose advice you are listening to.
........ what compression ratio would you think ........
No way to guess without knowing the piston specs, compression (pin) height in particular.
Originally Posted by J-(Chicago)
........ Bore diameter, stroke length, rod length, deck height, combustion chamber volume, cylinder head gasket compressed thickness, and cylinder head gasket bore diameter ........
The internet is full of bogus information. You need to pay more attention to where you get your information.
Try it with the specs from your own engine.
Norm
DennisG.
Vista Cruiser & Wagons
46
Jan 19, 2022 01:22 PM
Stefano
Aug 12, 2015 05:35 PM
197064buickspec
Mar 17, 2013 02:30 PM
leepear
Feb 17, 2013 05:33 AM
vistacruiser1971
Jan 4, 2012 10:47 AM
