455 1971 and HP
455 1971 and HP
Hi guys.
I'm behind a 1971 Cutlass 442.
I would like you to confirm that HP released the 455 from that time since I have read in some pages that its HP is 365, however, I have read in some other that it really is 260hp since in that year its configuration was for gasoline unleaded, so its under compression, therefore its HP.
Could you confirm?
The gearbox that this 442 uses is a TH400 if I'm not wrong.
On the other hand, when I did the first test that engine did not give me the feeling of being powerful. Last year I tested a 1972 Pontiac 455HO and it felt more twitchy.
Thank you.
Regards
Could you confirm?
Thank you.
Regards
Gracias por tu comentario v8al.
Del documento que has publicado me queda claro que posiblemente la publicación que leí estaba confundida con el motor Rocket 350 en lugar del 455, que tiene 80HP más que la época.
Gracias.
Saludos
You might get a better response if you start your own thread, rather than piggybacking on a one-and-a-half year old one on a different topic. Also, if you only want input from Joe, you should probably send him a PM and ask nicely, although I don't know if he does command performances.
