455 1971 and HP
Old May 19, 2023 | 04:29 PM
keyboard's Avatar
455 1971 and HP
Hi guys.
I'm behind a 1971 Cutlass 442.
I would like you to confirm that HP released the 455 from that time since I have read in some pages that its HP is 365, however, I have read in some other that it really is 260hp since in that year its configuration was for gasoline unleaded, so its under compression, therefore its HP.
Could you confirm?
The gearbox that this 442 uses is a TH400 if I'm not wrong.
On the other hand, when I did the first test that engine did not give me the feeling of being powerful. Last year I tested a 1972 Pontiac 455HO and it felt more twitchy.
Thank you.
Regards
Old May 19, 2023 | 04:36 PM
v8al's Avatar
Registered Olds Owner
An automatic 1971 442 would be equipped with a Turbo 400 transmission.
Here is the Gross versus Net horsepower for the 1971 engines from the 1971 Oldsmobile Power Teams brochure.
Old May 20, 2023 | 01:53 AM
keyboard's Avatar
Originally Posted by v8al
Un 442 automático de 1971 estaría equipado con una transmisión Turbo 400.
Aquí está la potencia bruta versus la potencia neta para los motores de 1971 del folleto Oldsmobile Power Teams de 1971.
Hola.
Gracias por tu comentario v8al.
Del documento que has publicado me queda claro que posiblemente la publicación que leí estaba confundida con el motor Rocket 350 en lugar del 455, que tiene 80HP más que la época.
Gracias.
Saludos
Old Oct 30, 2024 | 06:02 PM
442b's Avatar
Joe Padavano - Please decipher the VIN and Cowl Tags. These are from a car I'm looking at. My concern is the VIN tag, Looks too new. Thoughts?
Old Oct 30, 2024 | 07:17 PM
You might get a better response if you start your own thread, rather than piggybacking on a one-and-a-half year old one on a different topic. Also, if you only want input from Joe, you should probably send him a PM and ask nicely, although I don't know if he does command performances.
Old Oct 30, 2024 | 08:49 PM
442b's Avatar
Old Oct 31, 2024 | 06:42 PM
gs72's Avatar
72Cutlass S
Holy thread jacking Batman!!!
dragline
Dec 30, 2021 09:37 PM
70sx455
Jun 25, 2014 10:51 AM
1971gutlass
Mar 27, 2014 08:26 AM
help442onguam
Jul 19, 2011 10:35 AM
