425 will this carb work?
Old Nov 14, 2007 | 07:21 PM
arnyishere's Avatar
1967 Delta 88?
I am looking at purchase a 4bbl carb to replace the 4bbl that is on my 67' delta 88 w/ 425 H.C.. Will the edelbrock performer #1407 work?
Old Nov 15, 2007 | 12:35 PM
arnyishere's Avatar
1967 Delta 88?
Exclamation
PLease help!!! LOL
Old Nov 15, 2007 | 01:27 PM
Oldsguy's Avatar
Past Administrator
Arny, strictly on the cfm rating, that should be sufficient. Are you using a stock manifold? I think that carb is square bore so it should fit. I don't know if you will have trouble with the linkage or not. What kind of transmission is in your car? If it isn't a TH400 you might have to work to find linkage for the transmission kickdown function. I don't know. Maybe someone else could help you on that. Olds64 used a similar Edelbrock on his 394 in his '64 98 and the engine liked the carb but we had trouble with the linkage as I mentioned above.
Old Nov 15, 2007 | 04:42 PM
arnyishere's Avatar
1967 Delta 88?
Talking
It will be a stock manifold. I do have the th-400 automatic trans so hopefully I will be Ok. Thank you sooooooo much!
Old Nov 15, 2007 | 10:01 PM
88 coupe's Avatar
Junior Member
Originally Posted by arnyishere
........ 4bbl carb to replace the 4bbl that is on my ........
Is there a problem with the one you have? Normally, a quality rebuild is as good as, if not better than, an "off the shelf" aftermarket carb.
........ Will the Edelbrock performer #1407 work?
750 CFM is than adequate for most "street" applications.
If your intake is a "square bore" manifold, and the linkage clears, it should work as well as the original carb.
Norm
Old Nov 16, 2007 | 04:13 AM
arnyishere's Avatar
1967 Delta 88?
Well I said it that way to keep it simple. The car currently has a 2bbl on there. In 96' My dad had the 4bbl taken off (and the manifold) and had a 2bbl put on. (NOT SURE WHY!?) So now I ave the original 4bbl manifold and no 4bbl carb to go on it. And that's the "whole" story. Thanks
Old Nov 16, 2007 | 04:44 AM
Oldsguy's Avatar
Past Administrator
Ok then, that makes perfect sense. For what it is worth, I would recommend getting a quadrajet, it would be a perfect replacement. Danny Sarvis can sell you a rebuilt one for your car and the price would be the same or cheaper than a new Edelbrock. Just an idea.
Old Dec 1, 2007 | 07:18 AM
arnyishere's Avatar
1967 Delta 88?
Question
And how can I get a hold of said "Danny Sarvis"?
Old Dec 1, 2007 | 08:45 AM
If you search for his name in the ClassicOlds search engine you should find another post with his contact information. He is a quadrajet guru and his work is top notch. Also search for other "carburetor" or "quadrajet" posts.
Old Dec 6, 2007 | 09:47 AM
frdmftr's Avatar
Freedom Fighter
Here's a pic of my 67 Delta with the Edelbrock carb and intake. I finally figured out how to post the images.
steve walker
Dec 17, 2019 12:32 PM
smkn600ctd
Dec 29, 2014 05:38 PM
bluecab
May 22, 2012 08:36 AM
jabba
Oct 28, 2008 11:53 PM
65topless
May 13, 2008 09:25 AM
