394 performance parts
Old Apr 20, 2024 | 11:08 AM
Mikeyt's Avatar
Mikeyt
Going to look at, hopefully make a deal, on a 62 98 with a 394.
The plan is to run it as is and fix the small things for now.
I know myself though and once that's done I'll be looking for something else to do.
More power is always nice.
Is there any aftermarket performance support for these engines?
Intake manifold, headers, etc?
Google can't seem to find any.
Old Apr 20, 2024 | 11:33 AM
redoldsman's Avatar
Proud Viet Nam Veteran
About the only things you may find are used and are on places like ebay.
Old Apr 20, 2024 | 12:32 PM
Run to Rund's Avatar
Isky still has cams, lifters, etc,
Old Apr 20, 2024 | 12:47 PM
Mikeyt's Avatar
Mikeyt
I guess keeping it stock is my only option.
I guess that's a good thing for my wallet. Lol
Old Apr 20, 2024 | 12:58 PM
Sugar Bear's Avatar
Stock but tuned should give more than adequate performance. I'm guessing the 98's were all High Compression 4 barrel engines... anyone???
Dual exhaust would be nice.
Old Apr 20, 2024 | 06:53 PM
Charlie Jones's Avatar
Phantom Phixer
yes, they all were .
There are a few speed equipment manufacturers making stuff for 394's.
Besides Isky, Camcraft makes several 394 grinds,
.Automotive Performance Camshaft Production Manufacturer | Camcraft Cams
Offenhauser still makes new tri-carb and dual quad manifolds.
They are available through Exeter Auto Supply.
EAS - Offenhauser Catalog (exeterautosupply.com)
Old Apr 20, 2024 | 06:57 PM
rocketraider's Avatar
Oldsdruid
The SkyRocket 394 in the Ninety Eight was rated 330 horsepower. It would move a Ninety Eight out right smartly.
The 59-64 394 was the engine of choice for Gasser drag racing classes and there was tons of speed equipment made for them until the Chrysler 426 Street and Race Hemis appeared in 1964. The low-compression 2 barrel versions worked quite well with a GMC 71-series supercharger perched on top of them.
Old Apr 21, 2024 | 03:17 PM
Mikeyt's Avatar
Mikeyt
She definitely needs a tune.
Runs really rich and Trans shifts way too early.
Dual exhaust is first. Gotta chop off that single glass pack dumped at the axle. Sounds like a beat up farm truck right now.
Thanks for replying
Old Apr 21, 2024 | 03:21 PM
Mikeyt's Avatar
Mikeyt
Once I get her running right I'll add some performance parts.
tri carb would be cool
Old Apr 21, 2024 | 03:36 PM
Mikeyt's Avatar
Mikeyt
Motor purrs just as smooth but she shifts too quick and sounds like a farm truck but I think I'm in love.
Old Apr 21, 2024 | 05:18 PM
Sugar Bear's Avatar
Very nice looking ride!!!
Old Apr 21, 2024 | 06:17 PM
Phantom Phixer
If you don't already have one, an Oldsmobile shop manual is a very good investment.
These are the books Olds mechanics used at the dealership.
In 1962 Olds published a supplement to their 1961 Shop Manual.
You will need both books if you have a '62.
Among the many other things you will find in the shop manual, are instructions on how to adjust the transmission throttle linkage.
Printed original copies are preferred.
1961 oldsmobile shop manual 1962 for sale | eBay
There is a special adjustment tool that has to be used. They are available from JASWEST.
JASWEST - Product Catalog
A good dual exhaust system is highly recommended.
Luckily, the exhaust manifolds were the same in '62 for single or dual exhaust.
All you will need are mufflers and pipes. They are available from Waldron's.
Waldron's Exhaust – Car exhaust, truck exhaust, exhaust pipes, mufflers (waldronexhaust.com)
Old Apr 21, 2024 | 07:34 PM
Oldsdruid
See you're in NC. Whereabouts?
Old Apr 21, 2024 | 10:08 PM
Mikeyt's Avatar
Mikeyt
Thank you
Old Apr 21, 2024 | 10:09 PM
Mikeyt's Avatar
Mikeyt
Great info Thanks!
Just ordered both manuals. Man that's gonna be a big help!
Old Apr 21, 2024 | 10:10 PM
Mikeyt's Avatar
Mikeyt
Eastern NC, Beulaville
Old Apr 23, 2024 | 07:20 AM
Oldsfan's Avatar
There may not be anything wrong with that transmission. It is what they called a "Slim-Jim." They are a different animal. People tend to say unkind things about them. Damper plate bolted to the flywheel like a manual transmission. No external torque converter - it has a fluid coupling (that fills and empties) inside the trans behind the front pump. It will not shift like Turbo HydraMatic. Adjustment and fluid level are important.
Old Apr 23, 2024 | 08:11 AM
Mikeyt's Avatar
Mikeyt
It just shifts way too early no matter how much throttle you give it.
Old Apr 23, 2024 | 01:11 PM
Phantom Phixer
Make sure the linkage between the carb and the transmission is connected properly.
Old Apr 23, 2024 | 01:22 PM
kjr442's Avatar
Kjr442
394
I do know someone selling a bunch of 394 parts. One thing I thought was coo is the two 4 bbl intake.
Mikeyt's Avatar
Mikeyt
Will do.
Thanks again Charlie
FTolliver
Mar 19, 2023 06:49 AM
FTolliver
Jul 2, 2022 04:24 PM
INTRUDER
Dec 19, 2019 01:36 PM
jrok420
Jul 22, 2011 01:21 PM
44TEETWO
Jan 14, 2009 07:04 PM
