394 oil pressure spot
Old Mar 15, 2017 | 09:48 AM
MichiDan's Avatar
On a 394, assuming I leave the original light hooked up, where's a good secondary spot to tap in for an oil pressure gauge?
I got an electric gauge so the sender is fairly good size.
Old Mar 15, 2017 | 10:02 AM
D. Yaros's Avatar
The same place the current sending unit is connected. Put a Tee there and hook both up at the same location is what I would do.
Old Mar 15, 2017 | 10:43 AM
redoldsman's Avatar
Proud Viet Nam Veteran
The sender screws into the top of the oil filter adapter. To get good access, you may need to remove it. It has 4 bolts in it.
Old Mar 15, 2017 | 11:01 AM
Pressure senders don't care how far away from the engine they are. You can use brass pipe fittings and nipples to tee into the stock sender location and split off a port for the aftermarket sender. Put it wherever it needs to be.
Old Mar 16, 2017 | 05:43 AM
MichiDan's Avatar
Thanks all. I'll take a look this weekend and T it in.
Old Apr 3, 2017 | 05:28 PM
MichiDan's Avatar
A tight fit but doable.
DynamicIdiot
Jun 19, 2016 04:28 PM
394 Skyrocket
Jun 19, 2013 10:19 PM
foreverolds
Dec 1, 2012 07:07 PM
Swed Olds
Jul 15, 2010 12:21 AM
