394 oil pressure spot
On a 394, assuming I leave the original light hooked up, where's a good secondary spot to tap in for an oil pressure gauge?
I got an electric gauge so the sender is fairly good size.
Pressure senders don't care how far away from the engine they are. You can use brass pipe fittings and nipples to tee into the stock sender location and split off a port for the aftermarket sender. Put it wherever it needs to be.
